ผู้เขียน หัวข้อ: เอามาฝากครับ OBC Function สําหรับท่านที่ยังไม่ทราบ (ซ้ำขออภัยนะครับ) พอดีไปเจอมา  (อ่าน 21317 ครั้ง)
PiekPoon
  • กระทู้: 246
  • Golffy 323ise Grey Color
BMW Self-Test Mode Instructions:
Instructions to access the hidden functions:
1. Hold Trip Reset while turning ignition key to position 1.
2. LCD should show "Test 1.0"
3. Press the reset button again to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. Then with no delay, press Trip Reset several times to select one of the following functions.
BMW E46 On-Board Computer (OBC) Hidden Codes (works on some E36s as well):
1. Car Engine and cluster data
1.0 VIN number (last 5 digits)
1.1 K number (my car shows a mileage counter of some sort)
1.2 Cluster Part #
1.3 Coding (12)/diagnosis (34)/bus index (56) (ex. 123456)
1.4 Week/Year of cluster manufacture (ww/yy)
1.5 Hardware and Software cluster #s (ex. 09_160 = hardware '09' and software '16.0')
1.6 ?
1.7 CAN-version and KI-revision index (ex. 04_44 = CAN-version '04' and KI-revision index '44')
2. Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function (this is a fun one to watch).
3. Service Inspection Data
3.0 Used fuel in liters since last Service Inspection
3.1 elapsed days since last Service Inspection (mine reads zero, which doesn’t match)
4. Fuel Consumption
4.0 Instant fuel consumption (ex. 0145+ =14.5 liters/100km)
4.1 Instant fuel consumption (ex. 0018=1.8 l/Hour)
5. Distance Gone Consumption
5.0 Average mileage (ex. "082" = 8.2 liters/100km)
5.1 km to refuel
6. Fuel Level sensor inputs in liters
6.0 Fuel level averaged (ex. 109330+ = Left half sensor input 10.9 liters;
Right sensor input 33.0 liters)
6.1 Total tank level averaged: (10.9+33.0=43.9 liters)
6.2 Indicated value (0442+ = 44.2) and tank phase
7. Temperature and Speed
7.0 Coolant/Engine temperature (ex. 021 = 21C) (this one’s also really interesting. my car ranged from 82 to 98 C. once the engine was warmed up—leave this one on as you’re driving around).
7.1 Ambient/Outside temperature - chg met 5 pts. 125/130/135 .
7.2 Engine speed / Current RPMs 1/min
7.3 Vehicle speed / Current Speed in km/hour
8. Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 ADC Value brake degradation sensor (000=o.k.)
8.3 ? (mine read 38C000)
9. Battery
9.0 Battery Voltage (ex. 140 = 14.0v)
9.1 ?
9.2 ?
9.3 ?
10. Country of Destination? (mine read ----US)
11. ? (mine read FFFF08)
12. Not used
13. Gong Test—press trip button briefly to test chime.
14. ?
14.0 ? (mine read C78100)
14.1 ? (mine read 000000)
14.2 ? (mine read 000000)
14.3 ? (mine read 000000)
14.4 ? (mine read 000000)
15. Status cluster I/O-ports (bit codes) 0=low; 1=high (all these were hard to interpret)
1) belt contact, seat belt fastened=0; (fasten seat belt and you’ll see a change)
2) ignition lock contact, key inserted=0;
3) door contact, door open=0; (open or close door and you’ll see a change)
4) clock button pressed=0;
5) SI reset=0, for reset=0;
6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output;
2) Brake warning lamp;
3) Low fuel warning lamp;
4) EGA lamp;
5) seat belt lamp;
6) manipulation dot
16. ?
16.0 ?
16.1 ? (my car shows --lo--)
17. ? (a timer of some sort but doesn’t match up to any service interval or other event I can determine)
18. Not used
19. Lock Status; unlocks functions in range 3-18
19.0 L-On / L-Off (to unlock, press button when "L-Off")
20. ? (countdown timer of some sort)
20.0 displays what appears to be a meaningless number
20.1 counts down final digit
20.2 counts down next-to-last digit
20.3 counts down third-to-last digit
21 Software Reset; reset OBC settings (I didn’t want to mess with this one!)
00 End of test
kwan47
  • กระทู้: 703
ถ้าเป็นภาษาไทยก็จะดีกับสมาชิกท่านอื่นมากนะครับ
PiekPoon
  • กระทู้: 246
ไว้เด๋วว่างจะเอาภาษาไทยมาลงใหม่ครับ..
kwan47
  • กระทู้: 703
รออยู่นะครับ  รถผมมันขึ้นเกือบทุกดวงเลยครับ
Kittiisr
  • กระทู้: 220
รออยู่เหมือนกันครับ พออ่านได้ แต่ยังไม่เข้าใจบางอย่าง :-\
PiekPoon
  • กระทู้: 246
แปลเองนะครับ..เอาเบื้องต้นไปก่อน (จากการทดสอบด้วยตัวเอง)
ก่อนจะเข้าไปเซ็ตค่าหรือดูค่าต่างๆได้นั้นต้องปลดล๊อคมันซะก่อน..ซึ่งการปลดล๊อคนั่นทําได้โดย
- บิดสวิทช์กุญแจไปตําแหน่งที่ 1 ครับ
- กดปุ่มที่อยู่ด้านซ้ายบนหน้าปัทม์ค้างไว้ครับ จนมันขึ้นว่า " Test  "
- หลังจากนั้นกดเลือกโหมดไปที่โหมด 19 ครับ รอจนมันขึ้นคําว่า  " Off "  จากนั้นให้รีบกดปุ่มสั้นๆอย่างรวดเร็ว 1ครั้ง
-ต่อจากนั้นหน้าจอจะขึ้นว่า " Test " อีกครั้งครับ แต่คราวนี้เราสามารถกดปุ่มเพื่อเลือกเข้าไปในโหมดต่างๆได้แล้วครับโดยโหมดต่างๆจะขึ้นอยู่กับตัวเลขที่นําหน้า
นี่คือวิธีปลดล๊อคเพื่อเข้าไปใน Hidden Function ครับ ส่วนฟังก์ชั่นที่ 1-21 จะพยายามหาความหมายดูอีกทีนะครับ หรือใครรู้มากกว่านี้เอามาแชร์กันนะครับ
ปล.ที่ผมใช้ประจํามีอยู่ 2-3 ฟังก์ชั่นครับคือ
- 2    =  ฟังก์ชั่นนี้มันจะโชว์สถานะไฟบนหน้าปัทม์เราทั้งหมดเลยว่ายังทํางานปกติหรือป่าว..หลอดขาดมั้ยไรมั้ย(รึป่าวนะเห็นมันขึ้นหมด สวยดี)
- 7.2  =  ตัวเลขบนหน้าปัทม์เราจะกลายเป็นเหมือนวัดรอบดิจิตอลครับ
- 9.0  =  อันนี้ใช้ตรวจสอบแรงดันไฟฟ้าที่แบตเตอรี่ของเราคับ 120 คือ 12.0V หลังจากสตาร์ทแล้วควรเป็น 140 ซึ่งก็คือ 14.0v แสดงว่าไดชาร์ทเราชาร์จไฟปกติครับ
หากมีผู้รู้มากกว่านี้ก็ขอคําแนะนําด้วยนะครับ ยังใหม่กับ E 46 มากๆครับผม
 >:D    >:D    >:D
นั่งแปลร่วม สองชั่วโมง  หวังว่าคงจะเป็นประโยชน์กับพี่ๆน้องนะครับ.... ผิดพลาดประการใดช่วยชี้แนะด้วยนะครับ
เพราะมีหลายเมนูที่ผมเองก็ไม่ทราบครับ
คำสั่งโหมด ทดสอบตัวเอง ของ BMW
คำแนะนำ เพื่อเข้าโหมดที่ซ่อนอยู่ (สมองของรถ)
    กดปุ่มรีเซ็ตตัววัดระยะทาง(ด้านซ้ายมือของหน้าปัทม์รถ) พร้อมกับบิดสวิทช์กุญแจไปที่ตำแหน่งหนึ่ง คือตอนที่รถยังไม่ได้สตาร์ทแต่ฟังวิทยุเปิดได้นะครับ
                                                         ***เพิ่มเติมครับ   ตำแหน่งสอง คือตอนที่ไฟโชว์หน้าปัทม์ทุกดวงติดแต่รถยังไม่สตาร์ท
        ตำแหน่งสาม คือบิดเพื่อสตาร์รถ
        ตำแหน่งศูนย์ คือตอนที่เราล็อคคอพวงมาลัยและดึงกุญแจออก
     ที่หน้าจอควรจะขึ้นคำว่า "Test 1.0" ให้ปล่อยมือออก
     แล้วรีบกดปุ่มรีเซ็ตวัดระยะทางอีกหลายๆครั้ง(ปุ่มเดิมจากข้อ1) กดไปเรื่อยๆ จนหน้าป้ทม์โชว์ 19.0 เพื่อปลดล็อคทุกฟังชั่นที่ต้องการจะดูทั้งหมด
     รอให้หน้าปัทม์ โชว์  L_off ---> L_on ---> L_off
    กดปุ่มรีเซ็ตระยะทางอีกครั้ง ครั้งนี้ค้างไว้สัก 1/4 วินาทีแล้วค่อยปล่อย  (จริงๆก็คือการกดตกลงนั่นเองครับ ไม่ต้องกดค้างก็ได้เหมือนกันครับ ผมลองแล้ว)
     หลังจากข้อ 4 ก็กดปุ่ม รีเซ็ตระยะทางไปเรื่อยๆครับ จนกว่าจะถึง  ฟังชั่นที่ต้องการจะเรียกขึ้นมาดู ตามรายละเอียดด้านล่างนี้ครับห
     เกี่ยวกับเครื่องยนต์และข้อมูลของหน้าปัทม์
         แสดง Vehicle Identification Number (5 ตัวสุดท้าย)
         หมายเลข K (คืออะไรอันนี้ผมก็ไม่รู้ครับ)
1.2 Cluster Part #
         หมายเลข หน้าปัทม์ (น่าจะเป็น serial  no. ของหน้าปัทม์)
       (อันนี้ไม่ทราบครับ)
        สัปดาห์/ปี ที่ผลิตของหน้าปัทม์
1.6 ?
       version ของ CAN และ ค่าดัชนีของ KI-revision
     เกี่ยวกับการทดสอบไฟหน้าปัทม์ทั้งหมดรวมทั้งเข็มทุกเข็มบนหน้าปัทม์
     เกี่ยวกับข้อมูลการเข้ารับ Service
      น้ำมันที่ใช้ไปเป็นลิตร ตั้งแต่การเข้ารับ Service ครั้งสุดท้าย
      จำนวนวันตั้งแต่เข้ารับการ Service ครั้งสุดท้าย
4. Fuel Consumption
     เกี่ยวกับอัตราการสิ้นเปลืองเชื้อเพลิง
      อัตราสิ้นเปลีองน้ำมันเชื้อเพลิง ณ ปัจจุบัน แสดงเป็น ลิตร/100กม. ถ้าไม่ได้สตาร์ทเครื่องควรจะเป็น 0ลิตร/100km
      อัตราสิ้นเปลีองน้ำมันเชื้อเพลิง ณ ปัจจุบัน แสดงเป็น ลิตร/1ชม.
    เกี่ยวกับการวัดระยะ และอัตราสิ้นเปลีอง
      อัตราสิ้นเปลืองเฉลี่ย (ตั้งแต่เริ่มรีเซ็ตค่า)  แสดงเป็น ลิตร/100กม.
5.1 km to refuel
     ระยะทางที่รถจะวิ่งได้ก่อนน้ำมันหมด  แสดงเป็น กม.
     เกี่ยวกับระดับน้ำมันเชื้อเพลิง
6.0 Fuel level averaged (ex. 109330+ = Left half sensor input 10.9 liters;Right sensor input 33.0 liters)
      ระดับน้ำมันเฉลี่ย (ตัวอย่าง 109330+ หมายความว่า เซ็นเซอร์ตัวซ้ายอ่านค่าได้ 10.9 ลิตร; เซ็นเซอร์ตัวขวาอ่านค่าได้ 33 ลิต
         ระดับน้ำมันเเฉลี่ยน้ำมันคงเหลือในถัง
        ตัวชี้ค่า  (ไม่ทราบเหมือนกันว่าต่างจาก 6.1 ตรงไหนครับ)
      เกี่ยวกับอุณภูมิและความเร็ว
        อุณหภูมิของน้ำในหม้อน้ำ และ อุณหภมูของเครื่องยนต์ แสดงเป็น เซลเซียส
      อุณหภูมิภายนอกบริเวณตัวรถ
      ความเร็วรอบของเครื่องยนต์ ขณะที่ดูค่า  แสดงเป็น รอบ/นาที
     ความเร็วของรถ ขณะที่ดูค่า แสดงเป็น กม./ชม.
     เกี่ยวกับค่าในเลขฐาน 16
     แสดงระดับโวลท์ แสดงค่าโวลท์เป็นดิจิตอล (เลขฐาน16)
     (อันนี้คืออะไรไม่ทราบครับ)
      ค่าจากเซ็นเซอร์ตรวจสอลการเสื่อมสภาพของวาล์วระบบเบรค (degradation sensor) ต้องโชว์ 000 แปลว่ายังโอเคครับ
9. Battery
    เกี่ยวกับแบตเตอรี่
       ไฟของเเบตเตอรี่ ขณะที่วัดค่า ตอนที่ไม่ได้สตาร์เครื่องควรจะอยู่ที่ 13.2-13.5โวล์ท
       ถ้าสตาร์ทรถแล้วไดร์ชาร์ทต้องทำงาน ตัวเลขจะต้องวิ่งขึ้นไปที่ประมาณ 14.3-14.5โวล์ทแปลว่าไดร์ชาร์ททำงานปกติ
       หากสตาร์ทรถแล้ว อ่านค่าได้เท่าเดิม หรือต่ำกว่า14โวล์ทแปลว่าไดร์ชาร์ทไม่ทำงานห้ามขับรถออกไปเด็ดขาด
       เพราะดับกลางทางแน่นอนครับ และถ้าไดร์ชาร์ทไม่ทำงาน ไฟแบตสีแดงบนหน้าปัมท์จะโชว์ด้วยครับ
9.1 ?
9.2 ?
9.3 ?
       จุดหมายปลายทาง (น่าจะเป็นประเทศที่ส่ง คือของเราน่าจะต้องโชว์ว่า ---TH)
12. Not used
       ไม่ได้ใช้
       อันนี้ไม่ทราบครับ ว่า Gong test คืออะไร
14. ?
      สถานะของ cluster ช่องรับ/ส่งสัญญาณ แสดงเป็นบิท 0=ต่ำ 1=สูง (ค่าเหล่านี้ยากแก่การทำความเข้าใจ สำหรับคนทั่วไป คือสำหรับพวกช่างดูจะเข้าใจได้)
     สถานะของเข็มขัดนิรภัย (ลองคาดเข็มขัดหรือลองปลดเข็มขัดนิรภัยดูครับ)
    สถานะของกุญแจ   ถ้าเสียบกุญแจที่คอพวงมาลัยจะแสดงค่าเป็น 0
    สถานะประตูรถ ประตูเปิดแสองค่าเป็น 0
     ปุ่มนาฬิกาถูกกด=0
     อันนี้ไม่ทราบครับ
    อันนี้เดานะครับ Electronic Gear System ระบบเกียร์อิเลคทรอนิคส์ ถ้าเกิดข้อผิดพลาด โชว์ 0 ครับ
    สถารนะดิจิตอลเอาพุต 0 = ไม่ทำงาน, 1 = ทำงาน
1) Gong output;
    ค่าเอาพุตของ Gong
     ไฟเบรค
    ไฟเตือนน้ำมันใกล้หมด
4) EGA lamp;
    ไฟEGA
5) seat belt lamp;
    ไฟเข็มขัดนิรภัย
6) manipulation dot
    อันนี้ไม่ทราบครับ
16. ?
16.0 ?
18. Not used
       สถานะล็อค หรือ ปลดล็อค เมนู3-18 ที่อธิบายมาข้างบน
      สถานะปลดล็อค (วิธีปลดล็อคตามที่อธิบายข้างบนสุด)
       ตัวนับถอยหลัง   (คืออะไรไม่ทราบครับ)
         ตัวเลขอะไรก็ไม่รู้ ไม่มีความหมาย
        นับถอยหลัง หลักสุดท้าย
       นับถอยหลังก่อนหลักสุดท้าย
      นับถอยหลังก่อนหลักสุดท้าย3หลัก
      ล้างค่าซอฟแวร์ที่มีทั้งหมด กลับไปสู่ค่าเริ่มต้นที่โรงงานตั้งมา   (ผมว่าอย่าไปยุ่งกับเมนูนี้จะดีกว่านะครับ!)
00 End of test
« แก้ไขครั้งสุดท้าย: สิงหาคม 19, 2012, 19:24:59 โดย chaky »
สุดยอดเลย เดียวต้องลองเล่นมั่งละครับ :)) :)) :))
jason
  • กระทู้: 224
ท.ทหาร 330
  • กระทู้: 343
29_FEB_s3.46
ข้อมูลเพิ่มเติมครับ....  การเข้าถึง ฟังก์ชั่น OBC หรือที่เรียกว่า On Board Computer ของรถ BMW
สามารถเข้าเมนูต่างๆได้ ตลอดเวลา ไม่ว่าจะยังไม่สตาร์ทรถ (แต่ว่าต้องบิดกุญแจไปที่ตำแหน่ง2นะครับ)
หรือว่าสตาร์ทรถแล้ว หรือแม้แต่ขณะที่รถกำลังวิ่งอยู่(ไม่แนะนำให้กดเพราะว่าอาจจะทำให้เกิดอุบัติเหตุได้เนื่องจากมัวแต่ก้มๆเงยๆดูหน้าป้ทม์กับมองถนน)
วิธีการก็เหมือนเดิมครับ ก็คือ กดปุ่มที่เอาไว้ รีเซ็ท ตัวเลขวัดระยะทางค้างเอาไว้เลยครับ (ระยะทางรีเซ็ทเป็น 000.0km ก็ไม่เป็นไรครับ)เพราะหลังจาก
ออกจากระบบ OBC ฟังก์ชั่น ตัวเลยวัดระยะทางจะกลับมาเป็นเลขเดิมครับ ไม่ได้รีเซ็ทแต่อย่างใด
แต่หากว่าเวลากดพอเห็นตัวเลขวัดระยะทางมันเปลี่ยนเป็น 00 แล้วปล่อยมือออก ทีนี้ม้นก็จะรีเซ็ทค่าที่วัดระยะทางเอาไว้จริงๆครับ
เอาละต่อนะครับ
กดปุ่มรีเซ็ทระยะทางค้างเอาไว้นะครับ ประมาณ 5-10วินาที
ที่หน้าปัทม์ก็จะโชว์คำว่า test 1.0 ก็เริ่มกดเข้าไปดูในฟังก์ชั่นที่อยากจะดูได้ตามปกติเลยครับ
หากต้องการออกจาก ฟังก์ชั่น OBD ไม่ว่าคุณจะอยู่ที่เมนูไหน ก็ให้กด ป่มรีเซ็ท(ปุ่มเดิมนั่นแหละครับ)ค้างไว้อีก 5-10วินาที
หน้าปัทม์มันก็จะกลับมาเป็น เหมือนเดิม คือโหมดใช้รถปกติทั่วไปครับ....
หวังว่าคงจะเป็นประโยชน์กับทุกท่านนะครับผม.... :D
« แก้ไขครั้งสุดท้าย: ตุลาคม 28, 2012, 13:40:27 โดย chaky »
fahute46
  • กระทู้: 24
Osonline
  • ฝันให้ไกล-ไปให้ถึง..
  • กระทู้: 11
  • Let the good time.
iceswat
  • กระทู้: 56
เป็นประโยชน์มากครับเดี๋ยวจะลองไปเล่นดู ;)
tinity
  • กระทู้: 273
7. Temperature เราสามารถทำให้มันโชว์ใว้ที่ออนบอร์ดเพื่อดูตลอดเวลาใด้ไหมครับ   :-X
ahallaha
  • กระทู้: 11
  • ทุกการกระทำ ย่อมมีผลตามมาเสมอ
323 ia M52tu 2003 @Hp plus 9.5
รถเสีย  >>>  จอดอู่  ####  รถดี >>>  เที่ยวไปทั่ว
noon
  • กระทู้: 18
ถ้าสมมุติเราไปกด21 reset แล้วมันจะเป็นอะไรมั้ยครับ
